07-03-2015 01:12 PM
Same mistakes and now you even mess up the execution order. As a first step follow ALL my suggestion and don't repost until you actually do.
You are clearly not ready to do a program like this. You can't just randomly connect things and expect it to work.
Start with some LabVIEW tutorials first. We won't do your homework or exams.
07-03-2015 01:15 PM
sorry instead of timeout i changed into two modes as crlf
07-03-2015 01:20 PM
Why don't you start implementing my suggestions above instead?
We really don't care what you do unless you tell us the reason behind your actions and we can see even the slightest indication that you actually thought about the problem. Why would you do these changes? Makes absolutely no sense. In any case none of this is related to your main problems.
07-03-2015 01:30 PM - edited 07-03-2015 01:35 PM
Here is all I will say. You do the rest:
Make sure to wire all error terminals to ensure correct execution order of all the sequential operations. If an error occurs, handle it gracefully.
07-03-2015 04:20 PM
The above is not optimal, but should get you going.
A better way would be to create a listerner outside the loop (using "TCP create listener") and then wait for incoming connections using "TCP wait on listener". Do the communiations with the connection ID and close the connection when done. After the loop also close the listener ID.
Have a look at the shipping example TCP named service" for details.
