System Exec.vi output encoding
What is the standard output-encoding of System Exec.vi?
I am running System Exec.vi to gather system information with command cmd /c systeminfo on a machine with German language. The output contains german characters that are not displayed correctly. How can I change the encoding of standart output? I think it is ASCII encoded?
For example: Domäne is displayed as Dom„ne,    Größe is displayed as Gr”áe.
Thanks.
(3,915 Views)
This link might help you.
Pankaj
(3,883 Views)
The system Exec VI is creating a command line console, and command line tools executed from that wille generelly use the OEM codepage while Windows GUI applications use the ANSI codepage. The actually used codepages for both types depend on the system language setting. Generally the OEM (or originally called IBM) codepages were the codepages used in DOS. Microsoft used new codepage definitions for use under Windows, most likely just for the sake of being different than the rest Smiley Very Happy, and calls them ANSI codepages. The two differ for most languages mostly only in where the different extended characters are located, not so much in which characters they contain.
While LabVIEW could try to convert the returned string from OEM to ANSI this is a pretty tricky adventure since they don't always convert losslessly from one to the other, and specific user configurations might cause Windows to actually use pretty incompatible codepages for each of the two. So any attempt to convert the string might actually cause serious dataloss that is not reversable after the fact.
Rolf Kalbermatter
My Blog
(3,874 Views)
Accepted by topic author kahlenberg
Thanks for answers. I solved my problem by replacing those characters with german ones as shown in attachment.
(3,848 Views)
I have same case. But I use function in user32.dll
(3,060 Views)
