Synchronization issues (data acquisition with different sampling rates)
Using a NI PXI-e 1078 with 5 cards.
I'm trying to assign different sampling rates to each card, but there is a problem with the synchronization; every channel was fed the same square wave.
(2,331 Views)
Accepted by topic author A.Ramirez
I think I understand your problem.  The Waveform Graph doesn't display things with the right delta t right?  That makes sense from the help file Displaying Multiple Plots on Waveform Graphs
Convert the array of wfm to array of cluster of x, dx, y[]
"Should be" isn't "Is" -Jay
(2,289 Views)
