Hi all,
I'm building a PXI system using a 1078 PXIe chassis and i wanted to get a bit of advice on synchronising the above mentioned cards.
Is it possible to use the structure outlined in this article http://zone.ni.com/devzone/cda/epd/p/id/5299, instead of the M series card using a X series and with the addition of the PXIe-4357? Also, is ok to use different sampling rates as long as the blocks are the same for each device?
Chris
