The blink property holds a universal color for blinking (and a universal speed). The default color is yellow. In your case you should change it to gray. Go to tools>>options>>colors. You need to uncheck the checkbox about using default colors and change the blinking color to gray. Note that if you deploy this as an application you will need to set this in the app as well. I think this can be done through an INI file setting. Try searching the site for INI and color or blinking. Also, if you want each of them to blink to a different color, you'll have to create a reference array to say which LED is blinking and programmaticaly set them to T,F,T,F.
___________________
Try to take over the world!
