09-16-2009 12:24 AM
I've a problem with my project explorer. On one computer my project shows all .svn folders which are normally hidden. Because I'm working with autopopulating folders my project dependencies aren't clear because of the duplicate entries in the .svn folders.
I've attached a screenshot of my project explorer.
Joachim
09-16-2009 01:41 AM
Hi there
I can confirm this for
- LabVIEW 8.5.1 and .svn - folder NOT hidden
I have no problems with
- LabVIEW 8.6.1f1, .svn - folder hidden or not hidden
Are you sure the .svn folders are really hidden?
09-16-2009 01:43 AM
I believe this was changed in LV 2009, so I suggest you look through the upgrade notes.
Personally, I don't use auto-pop folders, so I don't have this problem. I think that you get a better experience if you only put the files you want easy access to into the project. The rest will be there as dependencies and you can see the disk hierarchy in the Files tab.
09-16-2009 02:08 AM
Hi tst,
I am currently working with LV2009. My problem was that only some folders are hidden on the file system. Now I changed it recursive to hidden and everything works fine.
Thanks for your response.
Joachim
