I´m programming an application using subpanels architecture and I am finding the following problem: The VI's loaded and run work well The first time I call them but the next times I try to run them, the error screen appears saying that they are not in a compatible state with that action. I think this has to do with the fact that I am not using the correct method to finish their execution.
Anything you could tell me would be very hepful.
Thank you so much.
