09-02-2013 10:25 AM
Hi Everyone,
I'm trying to gather data from an excel file using a Vlookup type code (Please post one if there already is one, I have looked in the forum but not seen one)
When I run the main program "search excel.vi" the 2nd subvi doesn't run. However it does run when I either have the subvi in highlight execution or if I just run the subVI.
Any help appreciated. I have attached all VIs and excel sheet
09-02-2013 10:25 AM - edited 09-02-2013 10:25 AM
basic excel file to test
PS I'm running labview 2012
09-02-2013 11:36 AM
One possible cause could be that currently the order of "Close Reference" nodes is not determined. I modified the "Read_Values_From_Excel.vi" to control execution of close reference -nodes with error wires and to close references after they are not needed. After this I was not able to replicate the error when running the main VI. See the attached VI. You could try to make to same changes also to write subVI and run some tests to see if the error is gone.
Couple of additional points:
- There is no need to use "Build Array" for errors. "Merge Errors" can be expanded to have additional error inputs.
- Currently Excel is unneccessarily opened and closed in each subVI. Code could be modified to pass the reference to opened Excel sheet from "Read_Values_From_Excel.vi" to the "Write" subVI. This way Excel would remain open and the execution speed is improved.
- While Loop in "Read values from Excel Arrayed.vi" is unneccessary
09-02-2013 01:20 PM
In addition to the specifics you got in tne other reply, a more general point is that anytime you see that code only works with execution highlighting turned on, you should be immediately be thinking "race condition".
Be on the look out for things that have to happen in a particular order, but that order isn't logically or explicitly enforced in the code. Remember that LV is inherently parallel and doesn't follow any sort of left-to-right, top-to-bottom execution order.
Mike...
