09-04-2013 04:29 PM
Hi Folks,
I'm very new to matlab, and am trying to get a program together that will read my library of electric fish recordings. It is a simple binary format that self-contains information necessary for reading it. After a couple days in front of the software, I have been able to write a single pass that dissects the first record from my file. However, I'd like to structure the data, so that I can easily browse through each of the appended records in a particular file. I've attatched the .vi file that I've come up with so far... I'm sure that I need to write a loop and append the data to an array or cluster, though the procedure for this eludes me. Is there a more efficent way to code this? Many thanks for any help you may be able to provide!
Best,
JG
Solved! Go to Solution.
09-04-2013 08:33 PM
Well, I made my cardinal mistake on the forums, and called Labview Matlab in my earlier post. Apologies. I've made some headway on this, with a loop that adds data to a structure...
Now, I would like to come up with a way of doing this more efficiently... Any ideas? Many thanks in advance!
09-05-2013 10:26 AM
Consider Scan from File. Also, close the file after the loop.
If you want more detailed help, please post the complete file format.
Lynn
