String To Time Stamp including milliseconds
Hi, The below image show me converting the time into a timestamp (and substituting the date from a different time stamp.
This works fine except for the miliseconds. you can see here the milliseconds are defines as "%2d" and this does not work. If I replace this with "%2u" or "%3u" then the VI will error (vi attached)
what am i doing wrong
Cheers, Alec
TimeStamp
Message 1 of 17
(4,483 Views)
This should be enough
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 17
(4,476 Views)
OK, NEARLY! and Thanks 🙂
The problem now, is the number i am inputting is milliseconds, and the time stamp number is fractions of a second.
ie. "1" and "100" both translate to 00:00:00.100
anyone know how to translate this?
how would i make the time "00:00:00.001"
Message 3 of 17
(4,465 Views)
Sorry I don't understand what you're asking for...
Epictetus
Antoine Chalons
Message 4 of 17
(4,462 Views)
using this vi. if you set miliseconds to 1, the (and the time is set to say 12:30:15 (12hrs, 30min, 15sec) then you get 12:30:15:1.
What do i need to do to set the time to "12:30:15.001"
so not 0.1 but 0.001
Message 5 of 17
(4,454 Views)
  It sounds like your formatting string is off.  In the last part of the first string in TiTou's example, note that the string is .%03d rather than just .%d
This makes a big difference in the final result.  I tried TiTou's code myself and entering 1 in the milliseconds produces .001 as expected.
Best wishes,
Steven I
Steven I
Message 6 of 17
(4,446 Views)
Oh...
so if it's 1 you want .100
so if it's 10 you want .010, right?
and if you have 100 what do you want? .001? if not, what would give you .001?
Epictetus
Antoine Chalons
Message 7 of 17
(4,445 Views)
well no.
if its 1 i want 001, if its
if its 10 i want 010
if its 100 i want 100 ...
Message 8 of 17
(4,434 Views)
well... is this not what you get with the VI I posted in my first answer?
Epictetus
Antoine Chalons
Message 9 of 17
(4,430 Views)
no,
if you enter 1 you get .1
if you enter 10 you get .1
if you enter 100 you get .1
if you enter 5 you get .5
if you enter 15 you get .15
if you enter 150 you get .15
i cant see how you can get .005
Message 10 of 17
(4,427 Views)
