09-11-2014 01:05 AM
The entry should be of the format "A-00-xxx-000" where A is a alphabet,0 is numeric and xxx is fixed cannot ne varied by user and - should remain as -, and this will be the fixed length... is it possible? If yes , kindly enlighten me!!!
09-11-2014 01:23 AM
You don't have any readymade option available in LabVIEW but you can code it at the back. You can add "-", maintain the size and do whatever you want, remember you have to enable the option "Update while typing" in the String properties.
09-11-2014 01:28 AM
09-11-2014 01:33 AM
Yes you have to use event structure, so when you enable the "Update while typing" the event will be fired whever you make any change at that instance itself. So based on the length of the string conactenate " - " to it.
09-11-2014 01:53 AM
09-11-2014 06:39 AM
I'm kind of thinking the Key Down? event might be better. That way you can discard the fact the the keyboard was even pressed for an invalid input.
09-11-2014 07:02 AM
I was nearly done with that .... the only problem I had the user had to do backspaces and than re-enter the value.... but know i've completely scrapped out that part... thanks all of you guys for your help
09-11-2014 07:20 AM
