02-24-2016 07:32 AM
The breakpoint fires once program VI started, but it shouldn't.
When I control the values on comparator, indeed TOP value is grater than BOTTOM value, so breakpoint fires correctly.
But these values must be equal.
Where I've been mistaken ?
Pavel
02-24-2016 07:39 AM - edited 02-24-2016 07:41 AM
@Pavel_47 wrote:Hello,
Pavel
Obviously it's not ever getting to the breakpoint! Turn on highlight execution (the lightbulb) and see where all the dots go. Besides being fun to look at, it gives valuable insight to what is going on with your code. 🙂
02-24-2016 07:46 AM
02-24-2016 07:52 AM
Highlighting doesn't work properly in my setup: when I start VI, it do some initialization, then wait for user clicks to "START".
Unfortunytely "START" action isn't sensed by VI in highlighted mode.
In the meantime I've modified a little bit the VI.
Now both values on comparator are exactly the same ... but breakpoint after ">" comparator fires nevertheless.
02-24-2016 07:56 AM
mikeporter a écrit :
You have 8 local variables, none of which are initialized to a known state. Heaven only knows what the result of your calculation will be.
A good way to determine whether you are overusing local variables is to count up the number you use and if the result is greater than 0, you may have a problem.
Mike...
Hello Mike,
All these variables come from controls/indicators on Front Panel, so theirs values are defined before execution (actually execution starts when user clicks on "START" button, i.e. after starting of VI)
02-24-2016 08:35 AM
@Pavel_47 wrote:Highlighting doesn't work properly in my setup: when I start VI, it do some initialization, then wait for user clicks to "START".
If Start action isn't "sensed" and the mechanical action for the start button is set to latching, make sure that the terminal for the Start button is in the Start event.
02-24-2016 08:44 AM - edited 02-24-2016 08:45 AM
What's the point of doing the same calculations twice and comparing them on the first iteration? One value is never going to be greater than the other....they are always equal. Why not initialize your shift register with 0 or +/- infinity so that you can eliminate those local variables outside the loop. And I assume they are the same calculations since i can't read a tiny image. Code is always better.
02-24-2016 08:54 AM
I've followed your suggestion and changed "START" button action for "latched".
Now it actionned whit highlight set ON.
But unfortunately I didn't see the moment when execution riched the breakpoint (just after "Boolean Crossing PtByPt" block).
But once on breakpoint I've visualized the values before ">" comparator ... and found that they are "Not Executed".
So, I'm a little bit confused to understand what is happening.
02-24-2016 08:58 AM - edited 02-24-2016 08:59 AM
Hi Pavel,
The breakpoint will fire whenever code execution comes to this point - unless it is a conditional breakpoint.
Is it a conditional breakpoint?
Wrong. In highlight mode your VI behaves the same except it runs much slower…
Are you sure they are the same? To the very last bit of the float?
02-24-2016 09:08 AM
Hello GerdW,
But it should come to this point ONLY if the TOP comparator value is grater than BOTTOM one. Isn't it ?
It's ordinary breakpoint.
Sure, but I was waiting for about 3 min, clicking time-to-time in "START", but execution didn't reach the location of interest.
On the above post I visualized probed values ... they are the same until 5 digit after point
Pavel
