Strange "Scan From String" to Timestamp Error
hi,
i am trying to parse my time-string into a Time Stamp with "Scan From String" but i get some strange Error(1).
The Code:
The Error:
can anyone confirm? do i have an error in my parser-string?
is it possibly related to this Bug
461196
Scan From String VI returns Error 1 with "%t" as the format string input
http://www.ni.com/product-documentation/52151/en/
that should be fixed?
my labview version is
LV 2014 Service Pack 1 -- Version 14.0.1 (32bit)
with the RealTime addon (but the code in question was not run on RT)
thanks for your time.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,153 Views)
Accepted by topic author jwscs
Why do you have the square brackets around the scan from string format string? They are not there when you generate the timestamp string so it will fail when trying to convert it back as they are expected to be there.
(blog)
(3,146 Views)
because i'm overworked and stupid????
i copied from an earlier project of mine .. and thought that was the syntax
thank you!
(3,140 Views)
