11-28-2013 01:23 AM
Dear all,
best
12-01-2013 04:04 PM
Your set point is set to zero, your process variable appears to be 8.181 i.e. too high and error (SP-PV) is negative, so the output of your controller should be negative (-8.181 x Kp). The controller output is clamped to be between 0.5 and -0.5, and it is -0.5V, which is what you would expect if your Kp is the 0.1 one (I can't see which set of gains it is).
So it appears to be correct ?
Note: linearity should be between 0 and 1 (read the manual). Keep this set to 1 until you know things are working and only change if you need nonlinearity with error.
12-04-2013 06:58 PM
Dear AndyClegg,
Yes, you are right! I mix the relationship between the set point value and the process variable. It is now clear to me.
Thank you very much!
best
