Strange Block VIs
Another block on my project is unknown. Does anyone knows how to find this block? Thanks.
(2,866 Views)
This is a property node for a control (implicit binding).
Maybe you should work through the basic LV tutorials. I am pretty sure that these items show up there....
Norbert
Norbert
Expert: Geometry
(2,859 Views)
-That is property node for the image indicator.
-If you have started just learning LabVIEW please check these links:
Start with below links to learn about LabVIEW programming
NI Learning Center
NI Getting Started
LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
Using the Context Help Window
LabVIEW Inbuilt Examples
uday
(2,856 Views)
In addition to the advice mentioned above, if you right-click on a node, the resulting menu usually has a "Help" selection - in the case of property nodes, you will usually get TWO "Help" selections - one for generic property help and one for help with the specific property chosen.
Bill
CLD
(Mid-Level minion.)
(2,816 Views)
