04-25-2014 11:46 AM
I am having trouble using stored procedures and need some guidance.
If I try to run the stored procedure code I get an error saying I am not providing a required input, but from the LabVIEW it looks like I am providing it.
But I keep getting this error.
The database table looks as follows:
@ID is generated in the procedure, it is looked up and inserted.
I do not have any ability to get into the database myself. This is a stored procedure writtin by my IT department's DB engineer. The above image has the required feilds highlighted in yellow that I needed to provide when my code runs.
Can anyone see where my mistake has been made?
Thanks for the feedback.
Ben
Solved! Go to Solution.
04-25-2014 03:12 PM - edited 04-25-2014 03:13 PM
The procedure isn't going to match up the parameter names with the values you provide. You only provide 5 params but there are 8 in the stored procedure. In your case, SerialNumber will be passed into ID, PartNumber into SerialNumber, etc. Add some blank params in your cluster if they aren't required.
04-25-2014 03:21 PM
Actually what i said may not be entirely true. It depends on the definition of the SP itself. Your picture just shows a list of the parameters but not necessarily in the same order as defined by the SP.
04-28-2014 10:06 AM
Aputman,
Thank you very much. That is exactly what I needed. I guess I was confused because my IT Database manager said those values were not required, but LabVIEW must require them. I put all of the paramaters in and just updated the ones I needed to. This solved my issues.
Cheers,
Ben
04-28-2014 10:57 AM
FYI, this is the way that i like to create my parameters. Hope it helps.
