09-28-2016 12:04 PM
@Paige5 wrote:Hello,
My problem is that I am reading from an array, so I need to use a for loop. I want the first value of the array to be subtracted from every other value as it comes in.
Thank you all very much for your help!
Look ma, no loop
09-28-2016 12:09 PM
Your code is pure Rube Goldberg. Your use of "select" can be replaced by a wire. You can use "delete from array" to get the first element and an array of the rest. Autoindex on the rest after subtracting the first to play the values in a slow loop or whatever you need to do.
10-04-2016 08:15 PM - edited 10-04-2016 08:16 PM
Thank you!
