Stoping VI inbetween when program seeking data from serial port.
I have an application in which I need to read data from two serial port one after other.
One read will read 14 byte and other 08 bytes(Just info).
Now in between if user need to stop the VI then how to stop it?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 8
(2,488 Views)
Hi Ranjeet,
check your stop condition and stop your VI. Check it twice (or more often) when you need to.
You should obey DATAFLOW in doing so…
Message 2 of 8
(2,477 Views)
A state machine could do this easily.  Just have a state to check for the stop (or any other events).
GCentral
Message 3 of 8
(2,450 Views)
Here is my VI
--Ranjeet
Message 4 of 8
(2,427 Views)
What modification I need?
--Ranjeet
Message 5 of 8
(2,418 Views)
Hi Ranjeet,
At first you should consider using the auto-cleanup tool before posting your VIs…
Next you should remove the local variables and use wires instead! THINK DATAFLOW!
Then you should not use a timeout of 200s for your serial port communication. As you can't break a VISARead function while it waits for some data on the port you really should use a different scheme for reading the ports!
As said before: use a state machine. You can stop the state machine after each state…
Message 6 of 8
(2,403 Views)
Thanks, next time I will keep this in mind(I wasnt aware of it ).
Ok will use wire
As you suggested, small timeout will work here? I think that is good idea. Ok l will try to use state machine. As I told in my question that I have two read, will I need to make same timeout?
--Ranjeet
Message 7 of 8
(2,393 Views)
Hi Ranjeet,
smaller timeouts should work too (default is 10s). The timeout value depends on the responsiveness of your devices. When you do some real error handling you might filter TimedOut-errors…
- You don't need to set the same timeout value for both ports, each is handled on its own.
Message 8 of 8
(2,381 Views)
