12-20-2016 09:20 PM
crossrulz,
My code consists of a main VI, with several Sub VIs nested within one another. I would like one of the deepest Sub VIs to quit early (safely) when I press a stop button on the main VI front panel. It sounds like you are saying this is possible with a notifier. Can you please elaborate. I have a little experience with queues and producer/consumer type architecture, but have never used notifiers, nor queues to sub VIs. Any example code would be extremely helpful.
12-21-2016 05:56 AM
@accuairjohnathan wrote:
crossrulz,
I wish I had an example ready. I would use a Queue to send messages to your subVI and then you can send a specific Stop message to it using the queue. I recommend playing around with the Producer/Consumer until you get used to how queues work. Then you can create a control for the queue reference and use that to pass the queue reference into a subVI and everything just works.
12-21-2016 08:55 PM
Here's an example with code patterns you can use. The notifier is created at the top level and passed to all callers. Processes in the callers run until the notifier is invalid. To quit the app, release the notifier. (In this code pattern, "notification" is never actually sent; we just release the notifier.) We call this pattern "scuttling."
To run a process as fast as possible, just check the refnum status. To run it periodically (once every sec etc), wait on notification with a timeout. This is very valuable; it allows you to have a process do a task once per day while still quitting promply on user request.
Every other process should be constructed so that it will quit when this "quit notifier" is released. To do a processing task, throw it in a queue and have a queue processing process it. Set the queue up so that it is released by the notifier release. All of these will fall like dominoes when you release the quit notifier.
Any task that is many to one should be a queue. Any task that is one to many should be notifier. (Many to many is either a queue if you are load-balancing, or a notifier if you are broadcasting.)
LabView queues and notifiers are very similar internally. They are the best feature of the language; they makes safe parallel processing trivially easy, and they are much easier to develop and debug than the callbacks used in many languages.
