12-05-2014 11:41 AM
I am controlling a Phidget stepper motor using the VI captured below which includes a loop. I simply wish to record the speed of the motor as it runs into a text file or similar.
Currently i am trying to create an array and then output that as a file once the loop has stopped. This isn't giving me anything
Unfortunately i have very little LabView knowledge... is there a simple and effective way i could do this?
Any help would be much appreciated.
12-05-2014 12:44 PM
Look into Shift Registers.
12-05-2014 12:45 PM - edited 12-05-2014 12:45 PM
And by the way, your VI was never attached.
12-05-2014 02:20 PM
Your description of your project was a little vague. Also, no code/image was posted as was noted above. And, you do not run stuff into a text file. You store data in one. What are you using to record this data? Are you using a constant for the amount of iterations/samples you wish to take or is this going to be dependent on a User Control?
