08-11-2015 07:28 AM
Hey I'm looking to create limit lines for an insertion loss test. The spec limits to be used come from a string containing (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) basically meaning a .34 limit line @ 1, a .82 limit line @10, etc...essentially creating a segmented or stepped spec line. Any direction on how I might be able to do this would be much appreciated. Thank you!
Solved! Go to Solution.
08-11-2015 07:34 AM
How to do what? You haven't told us how LabVIEW plays into this.
Are your questions about interfacing with the hardware? How to display lines on a graph? How to architect an entire application for you based on a few sentence specification?
08-11-2015 07:39 AM
This link should be of use to you. Happy drawing! 🙂
08-11-2015 07:41 AM
I think he just wants to plot some S-Param data with some limit lines. I'm assuming in and out of band specs. 🙂
08-11-2015 07:45 AM
I have a string coming in from a SQL database, that string contains specs in dB with corresponding frequencies. I was wondering if possible there was a way to take each value from that string in order to create an array that will later be used to create spec lines for my insertion loss test....in LabVIEW.
08-11-2015 07:56 AM
I'm no expert with SQL, but it should be very easy to do that. I'm guessing you're having trouble with the SQL part?
08-11-2015 10:14 AM
No I'm not having trouble with SQL, I'm able to pull the string with the specs. My issue is I dont know how to take the values (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) contained in the string and break them into each individual spec value.
08-11-2015 10:17 AM
08-11-2015 10:33 AM
GerdW,
Thats what I had thought to use originally(minus the decimate 1d array). I used the spreadsheet string to array function followe by the decimate 1D array. the string (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) enters into the spreadsheet string to array function, and then outputs 0...as if nothing was even inputted. Attached is a screen shot of my setup as well as probes documenting the data flow.
08-11-2015 11:17 AM
