07-17-2014 12:28 PM
Hello All,
Would like to know if it is possible to configure an analog output instrument card (with DAQmx I presume) to have a static/continuous output, without needing to use a while loop. I wouls want to send it a single value,rather than an array or a waveform. This would be similar to the option for digital I/O cards to have static channels instead of waveform channels. From the examples I have seen, there always seems to be a while loop needed, even if the channel is setup for a single sample, but I think it would be cleaner and easier to control dynamically without the loop (particularily if I am running several VIs in parallel). My particular application involves configuring the Analog I/O, then running various tests with other instrument cards. Please advise. Thanks.
GSinMN
Solved! Go to Solution.
07-17-2014 12:37 PM
07-17-2014 12:53 PM
That was easy. Thanks for the quick response, Dennis. Probably no need to sift through through the examples again if I just plain misunderstood the function. If I know that all I need to do is start the task, set the single sample and pass the handle out of the subVI, I can retrieve it later to stop and clear the task whenever everything else is complete.
Thanks again,
GSinMN
