Statemachine Eventlist
You also need to attach your State_EventList VI so we can see how you have that set up.
GCentral
Message 21 of 24
(456 Views)
Message 22 of 24
(451 Views)
Accepted by topic author Martin88
Ok, you seem to have missed the point of the Action Engine.  The Action Engine itself is supposed to hold any information that it is in charge of.  In this case, it is the file path and the previous state.  I cleaned up your VIs quite a bit and redid some of your state saving logic.  I made it so that you only log the state if the state gets changed.  Repeated states will not cause the file to be written to.
GCentral
Message 23 of 24
(439 Views)
Thanks a lot crossruiz i would never come up with this solution!!
Best
Martin
Message 24 of 24
(430 Views)
