11-28-2006 03:05 PM
11-30-2006 05:14 PM
12-01-2006 08:25 AM
Updates from support.
Here's the message received from the PSE:
CAR 43TEEPSM
For Ben, tell him to :
- make the "Exit" state non-terminal (right click to do this)
- move the "default" arrow far enough away from the exit state until the red dot appears, then return it to the exit state
- make the "Exit" state terminal again.
All should be well.
Here's some additional information that may be more helpful/insightful for
you:
"adjust the "dots" that appear when you select a transition so that they
are reasonable - for transitions that go to/from the same state, move
the arrow away from the state far enough for the red dot to show up,
then return to the state it came from. For hidden transitions
(default transition on terminal states), make the state non-terminal,
adjust the default transition, then make the state terminal again."
That is the text provided in the CAR as it stands right now.
Ben
12-01-2006 08:33 AM
12-01-2006 08:42 AM
When the merry-go-round circles back around, I'll let you know if I can "grab the brass ring".
Ben
12-01-2006 02:30 PM
@Ben wrote:
When the merry-go-round circles back around...
Ouch (but effective).
Perhaps we can be a bit more helpful. Use the attached VI to replace the one with the same name in
<LabVIEW>\resource\plugins\statemachine\StateEditor.llb.
Please verify this fixes your problem. If yes, I will get it posted to a KB.
Roy
12-01-2006 03:05 PM
12-06-2006 03:41 PM
This was reported to R&D (# 43TEEPSM) for further investigation.
This notification posted for tracking purposes.
Chris C
01-08-2007 03:02 PM
Looks like I never updated this thread.
Both the work-around and the patch work fine.
Ben
