07-29-2014 10:28 AM
07-29-2014 10:48 AM - edited 07-29-2014 10:49 AM
This is where I found the driver: http://www.chromaate.com/(S(fqaqdsno3s4zjl52gafwaicx))/drivers/index
I picked both links for the 62000P series (I just realized that the first one was for LabWindows.. although it seemed to be a NI IVI package). Currently, I have uninstalled the LabWindows driver and deleted the IVI sessions for the chr26000. It is still working inside LabVIEW but not as a .exe.
I unzipped the LabVIEW package in my project folder. Then I included the VI library in my project and set the .dll path to that same folder.
And yes the chroma dll is located in the data folder underneath the exe.
07-29-2014 11:38 AM
07-30-2014 06:42 AM
Well, I think that the second package available (says its for LabWindows) on the Chroma website refers to what you're talking about. It's an IVI installer that placed a .dll file under the IVI foundation folder in program files. It also added the chr62000 to my driver sessions in the MAX.
Although, I've never used that kind of installer before, so I'm not sure how I would call the Chroma's VI only using that package. Could you give me any information? Am I supposed to use the VIs from the first LabVIEW package?
Does the IVI installer create VIs inside LabVIEW or do I still need to import them?
07-31-2014 09:56 AM
Hi mxmxm,
You should be using the VI's from the first LabVIEW package. The other package you downloaded would be specifically for LabWindows and to my knowledge the VI's installed using that installer would be inaccessible from LabVIEW. Could you give me a better understanding of your file layout within your .exe?
There is an option under the application properties >> Advanced that says "Use 8.x file layout". Try using this option and see if it changes anything.
08-27-2014 09:37 PM
Just rolled the 8-Ball
What exactly is the OS? Windows x.x? Home, or Enterprise?
It seems like the "Home Premium" edition has some restrictions on writing to C:\<whatever> from an app located in <Program Files> Just an unusual experience I had lately.........
Try moving your app to a new folder on the desktop.
