08-02-2010 04:02 AM - edited 08-02-2010 04:02 AM
Hello, Can someone kindly provide me the . icd fle for the following camera: Dalsa Spyder3 S3-20-04k40..
Thanks in advance..
chi_visor
08-02-2010 04:36 AM
Did you try contacting dalsa?
08-03-2010 03:41 AM
Actually not. I thought it should be available on NI since i could find files for other cameras. I'll check with them.
08-03-2010 03:47 AM - last edited on 04-15-2024 01:35 PM by Content Cleaner
You can also create your own
08-04-2010 12:51 AM
Ive tried using NI Camera File Generator and also configured all the attributes but it doesnt seem to work. I can see the commands working in the test serial settings but it doesnt seem to work when i change it in Measurement & Automation Explorer.
Any idea what could be wrong?
08-04-2010 04:40 AM
contacted Dalsa. They said thet do not provide support for NI frame grabbers.
10-15-2010 12:32 AM
Have you soluted this problem? I have a dalsa S2-2X-04k40 linescan camera,but i can't find the dalsa S2-2X-04k40.icd in the Imaq data document. What can i do ?
10-15-2010 02:08 AM - last edited on 04-15-2024 01:36 PM by Content Cleaner
First of all really sorry for not posting an update on this topic as I have got the solution to the problem by using the NI Camera File Generator.
It did not work for me in the first go. After some tweaking i realized that we have to give some delay after sending every serial command. This can be done in serial settings. It solved all my problems.
@ laogao:
If you dont have .icd file use NI Camera File Generator. I think you should be able to configure it. I would suggest searching the NI database online as well, you might find an update for your camera file.
10-16-2013 03:55 PM
Hello guys,
I am trying to use thos camera as well, did you guys mange to make it work?? did ysomeone got the file??
Efrain
