11-21-2014 02:14 AM
Hello All,
Please tell me how can I convert this type strings to array directly?
11-21-2014 02:34 AM
Hi Munna,
you need to search/split the groups in quotation marks first. After splitting the string into subsets you can convert each subset on its own and build an array of the results…
SpreadsheetStringToArray will not do what you want.
11-21-2014 03:17 AM
Hi GerdW,
Thanks for your help.
I’m just thinking how CSV (if I open same string in csv file) is giving correct result (as I expected).
I thought Spreadsheet string to array also will give same result.
Thanks for your confirmation.
11-21-2014 04:36 AM
Something like the VI below (LV2013) may work, but it needs for sure some improvements.
11-21-2014 04:46 AM
Can you please attach the VI in 2012 version.
11-21-2014 10:28 AM
P@Anand wrote:Can you please attach the VI in 2012 version.
LV2012
