11-12-2015 05:58 PM
11-13-2015 04:32 AM
You can use an intensity chart. Send consecutive spectra to it as a 1D arrays.
11-13-2015 10:39 PM
Attached is a snippet of the VI I've been working with. I'm working off of the example "Moving STFT PtByPt.vi" so I've attempted to implement the STFT PtByPt VI. Unfortunately, I am still not seeing the results I have exepted. The spectrogram appears to move/scroll the way I want it to, however the data displayed on the intesity graph does not seem rigth. I have arbitrarily set "sample length" to 100, "window length" to 50, and "window selector" to "Hanning". The IQ data is in complex format. I noticed that there seems to be warning (red dot) on the "x" input of STFT PtByPt VI. Can this VI handle complex input data? Attached is a screen shot of the context help for this VI. Additionally, the recorded IQ data is has a bandwidth of 40 MHz, center frequency of 2.4482 GHz, and sample rate of 50 Msps (samples per second).
11-13-2015 10:40 PM
ToeCutter - thanks. I've implemented the STFT PtByPt with an intensity graph. still not seeing what i would expect.
11-16-2015 04:16 AM
Well, I took spectrogram to mean 'spectrum' but I see it is a somewhat distinct concept. The output of the spectrogram is a 2D array, so you're out of luck, you can't have a waterfall display of 2D snapshots- waterfalls are created by stacking 1D arrays.
The cast *could* be because it doesn't expect a complex input.
As a starter for 10, take an array of say 1 second of your complex data. Shove it into 'FFT spectrum (mah-phase)' and you should get a 1D array out. Extract just the magnitude out (or you may want to square the magnitude to get a measure in terms of intensity/power or the like) and pass that 1D array to a waveform CHART (not graph). Does that give you the kind of thing you want?
