03-27-2012 10:06 AM
What are you doing with Excel? Did you give the file an .xls extension? That does not make it an Excel file. It's still a text file with an incorrect extension.
03-27-2012 11:04 AM
03-27-2012 11:31 AM
Same thing. Saving it as an Excel file requires a specific format. Evidently your's does not match. Save it as .txt and use Excel to Import it.
03-28-2012 05:39 AM
Hello I tried to change the beginning header by using controls instead so that the user can choose the unit of each value, but the error about the format came out like in the attached file. And how can I link these control units to the data mainstream. The user only adjusts the unit from these controls, then it will correspond in the main stream.
04-09-2012 05:04 PM
After I have tried to rearrange my code to save the files, it looks good. The file has everything I expected, except one thing; there is an extra "NaN" in my file. even though the number of NaN in the array is equal to the data inputs. You can see in my text file.
04-09-2012 05:05 PM
2 more sub vi
