03-23-2012 06:50 AM
Hello I got a problem with arranging data in the way I want. I cannot save each type of data in a row. It appears in a column.
The things I want to have in the file are; for example,
Date/Time
[ time Flow1 Pressure1 Flow2 Pressure3 Flow3 Pressure2
12:34:05 4 5 6 7 12 14
12:34:06 5 6 1 2 5 10
I also want to limit the user to have only 1 unit for Flow and Pressure for each measurement period till the stop button is pressed and be able to change the unit for the next measurement.
Sorry for asking you for a lot of tasks, but hopefully you could help
thank you
Solved! Go to Solution.
03-23-2012 10:25 AM
This is what I have got. I can't have only one data/time on the top. It comes with every set of data. I also don't know how to arrange data to be in the same lines as the headers.
03-23-2012 10:27 AM
My suggestion is to create some dummy data and debug your VI.
Comment out the wavegraph graphing during this process.
03-23-2012 02:58 PM
Sorry I don't understand what you meant by debugging? I am pretty new to this software. Which function should I use to make the data look like what I want?
03-23-2012 09:19 PM - edited 03-23-2012 09:20 PM
I mean that you have too much going on your VI.
Create a copy and remove everything and just have the file writing part of it.
LabVIEW is like any other software. If what you write doesn't work, then you have to simplify it so you understand what you just wrote.
When I run your VI and remove the extraneous stuff, the file that is created has text that is row by row. So I don't understand what makes you think it isn't working.
03-24-2012 03:05 AM
Do one thing.
Open excel or notepad and create a report file manually. This file should reflect what exactly should be the format of file you are expecting.
then post it in the thread. it will help us to understand what you want to do, and then i can give you some sample code.
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
03-24-2012 05:51 AM
Here we go. I attached the notepad file read from my programming file. It doesn't look even closely to what I really want. I really can't figure it out. Could you please give me a code to be able to get the result which I want.
In my vi, the problem is only the last loop (saving loop) in order to save in the right format. The loops before this loop (on the left) are just sendind data to the saving loop. Could you please tell me the block functions I should use to get what I want above or give me a simple code or fix my vi?
There should be only one Date/time and one unit each measurement or loop like;
[ Date/Time Flow Pressure
24.03.2012 / 12:25 l/min bar ]
time (m/sec) flow1 flow2 flow3 pressure1 pressure2 pressure3
12:25:35 3 3 2 4 5 6
12:25:36 8 2 1 6 10 4
I don't really know how to do this. I would appreciate if you help. Thank you so much.
03-24-2012 08:40 AM
As I wrote before, your original VI works for me in that the rows of data are written one row at a time, so I don't understand what is the problem you are having.
03-24-2012 09:06 AM
As you can see in the saved file, Date/time comes with every row of data. I want it to begin with
date/time Flow Pressure
..... (unit) (unit) --------} only shown one time. not every row
then start with
time flow1 flow2 flow3 pressure1 pressure2 pressure3
--- (value) (value) (value) (value) (value) (value)
till I press "stop"
then begin with
........... (unit) (unit)
then
data...
Hope you understand. Thank you so much for helps. I am really struggling now
03-24-2012 09:12 AM
Since the text from the file is being read in one row at a time, but you apparently want to create three rows of data from that one row then you need to re-arrange the text to create three lines of text that can be written to a file.
Usually it is best to do this type of processing after you stop your loop.
