Source sine Current through USRP using LabVIEW
I am using USRP N210 with LFTX/RX boards for Wired communication (Electromagnetic Induction) and programming using LabVIEW and have downloaded the drivers. I need to command the USRP to send a sine signal of 1MHz through the wire. I have used "Simulate Sine block" but am unsure of the blocks to which this must be wired to. Please let me know the steps or the blocks/VIs which might be helpful.
Thank you.
(2,313 Views)
