04-23-2007 11:09 AM
04-24-2007 10:39 AM
Hello RRRRSSSS,
Have you gotten a chance to look at the shipping examples that come with LabVIEW? There are some from the Example Finder that I think may work in this situation (trying to play a file continuously).
Look at Play Sound.vi, which plays a sound using the sndPlaySound Windows API. This demonstrates how to use the Call Library Function to call a DLL.
Sound File to Sound Output.vi also illustrates how to play a sound file continuously, reading the sound file in pieces, and playing each piece at a time.
Good luck!
Janell R | applications engineer
04-24-2007 11:50 AM
"Sound file to sound output "is what my vi is made from, the example only play's once.
I made an attempt to modify it and cannot get it to play once and repeat.
04-24-2007 03:58 PM
04-25-2007 07:07 AM
I did not find a " Play sound file' , I found a 'Play sound" example.
In addition to what I have I need to be able to set the volume, which does not seem possible in "play sound".
I have a working program with the older LV 6.1 sound files, but I was wanting to use the 8.2 vi 's , figured just replace them and it would be good to go but this has not been the case.
04-25-2007 08:10 AM
Hi RRRRSSSS,
See attached image. The idea is to read the WAV file and then run the sound data in a loop. You could keep loop delay to 1ms. In my case 10ms worked fine.
I could get my sound data to play as long as I hit the 'Stop' button.
Hope this helps.
- Gurdas
04-25-2007 08:56 AM
01-08-2009 10:12 AM
The soundOutput.vi file is exactly what I wanted done except I need to add something to the code which would search for a wav file in a folder and then play it.
Any help would be appreciated. I am new to Labview and I have no idea how to start it.
01-08-2009 12:37 PM
01-14-2013 03:16 PM
I leave an example which can contribute
