I use the example program "SVXMPL_Swept Sine FRF(DAQmx).vi" to test the frequency response of my DUT. Some frequencies whose level should lower than -40dBV, tested with "SVXMPL_Swept Sine FRF(DAQmx).vi", their sound level is higher than -40dBV.
If use " SVXMPL_One Shot Gain and Distortion(DAQmx).vi" to test the frequency response one by one, the sound level is right.
I guess there are some error in the Swept sine toolkit or my setting is error. I have try my best to use the same setting when using the two VIs. Following is the setting comparision:
SVXMPL_Swept Sine FRF(DAQmx).vi SVXMPL_One Shot Gain and Distortion(DAQmx).vi
amplitude input: 51.2mV amplitude input: 51.2mV
propagation time [samples]: 108 propagation time [samples]: 108
sampling frequency [Hz]:50000HZ sampling frequency [Hz]:50000HZ (set with "svx_override_DAQmx
Parameters.vi")
block duration [ms]: 500ms block size: 25000 (set with "svx_override_DAQmx Parameters.vi")
settling time:100ms settling time:100ms
settle cycles:10 settle cycles:10
integration time [s]:100ms integration time [s]:100ms
integration cycles:10 integration cycles:10
sweep frequencies [Hz]: frequency [Hz]:100HZ
start freq=100HZ
stop freq=100HZ
number of steps=1
The output sound level of the two VI is:
-38dBV -41.79dBV
I found the time Record of "SVXMPL_Swept Sine FRF(DAQmx).vi" is abnormal, pls find the attached picture "swept.png", there are abnormal higher signal at the start and stop terminal. which caused the sound level lower than -40dBV can't be test rightly. However, the time record picture one-shot.png of "SVXMPL_One Shot Gain and Distortion(DAQmx).vi" is normal.
Can't anyone help me?! Why one shot test and swept sine test at one frequency are different?
