Sort Data by columns in a multicolumn listbox
I have a multi-column listbox on the front panel with columns such as Name, Type, Date Modified, Size.
Is there any way to provide a facility to the user to sort the data in the listbox column-wise during run-time?  It should be similar to the one provided in Windows Explorer wherein the user can sort the data either by Name, Type, Size etc.
Siddharth
Message 1 of 12
(9,829 Views)
HI
           This sorting can be done it  in different ways. I have attached a Vi hope this helps you. Here i am sorting the 1st column wrt alphabetical order.
           Let me know if this works.
Message 2 of 12
(9,821 Views)
Hey,
i think it should be good !
I hope it is what you're looking for !
(Thanks to AutoTEC for sorting a 2D array ! 🙂 lool)
Let me know if it helps you !
Best regards, Vincent.
PS. : the Vi is in 8.5. You just have to run, and click on the name of the column you want to sort.
V-F
Message 3 of 12
(9,808 Views)
Thanks for your response. I am using Labview 8.2 and hence unable to open the VIs sent by you. Can you please let me know how do I open these Vi's in Labview 8.2.?
Siddharth
Message 4 of 12
(9,788 Views)
Thanks for your response. I am using Labview 8.2 and hence unable to open the VI sent by you. Can you please let me know how do I open these VI in Labview 8.2.?
Siddharth
Message 5 of 12
(9,785 Views)
Accepted by topic author Siddharth D
OK,  i joined the vi in Labview 8.0.
Let me know if it works.
V-F
Message 6 of 12
(9,777 Views)
Thanks for your help. It works!!!!!
Message 7 of 12
(9,754 Views)
Siddharth
Hi Siddharth,
Have a look at the attachments & pl reply back if they fir your requirement like a 'T'. Smiley Wink
Both are saved for LV 8.0. Smiley Happy
- Partha ( CLD until Oct 2024 🙂 )
Message 8 of 12
(9,726 Views)
Tried your VI and it only works if there are no identical items in a column and you click on that column.   This is because the search function stops the first time it finds a value.  Identical values will be removed by the sort.
Also, the test for greater than or equal 0 means that there will be an already sorted result waiting which will execute next time you click in the main part of the list box (which returns a minus 2).  This test should be made before the sort.
Sorry,
Carsten
Message 9 of 12
(9,511 Views)
I know that this is an ancient thread, but I thought I'd add a sorting algorithm that works with data that has duplicates in it. Carsten is correct that a check should be performed before this sort is executed to ensure that the column index is not negative.
Message 10 of 12
(6,375 Views)
