11-28-2006 03:36 PM
11-28-2006 04:03 PM
11-28-2006 04:07 PM
First of all, you're not reading or writing any files in Excel (*.xls) format. You're reading and writing plain ASCII spreadsheet data. (The fact that Excel will try its best to parse the content when you later try to open it with excel does not make it an Excel file ;)).
It is not obvious from the picture where the problem is, especially since we don't see the code in all the other cases and you read your filename via a value property. Where else is the file name used? It might be more efficient to open the file once, then use low-level file I/O to read from it and write back to it at desired offset location without ever closing the file during the run of the program.
Why don't you attach the actual VI so we can better see what you're doing?
11-28-2006 04:32 PM
11-28-2006 04:40 PM
11-28-2006 04:43 PM
11-28-2006 04:52 PM
11-28-2006 05:13 PM
11-28-2006 05:41 PM
11-28-2006 06:30 PM
