11-03-2014 06:38 AM
I am trying to programmatically set the BG colour for a Numeric indicator by feeding a color constant to the relevant property node as in the attachment.
However I am only getting a outline color instead of solid color background. Unable to get over this issue.
Solved! Go to Solution.
11-03-2014 06:48 AM - edited 11-03-2014 06:51 AM
You must use Numeric Text.Text Color.BG Color instead of Numeric Text.Color.BG Color.
11-03-2014 10:03 AM
Thanks. It worked.
Also I noticed another thing in the process ....
When you right click the Property node , there is an option for Name Format. And when you choose "Short" which is what I had orginally done, it simply reads "NumText.BGColor" for both options. When I chose the "Long" option I could see the difference and chose the right one.
