11-11-2014 02:22 AM
11-11-2014 09:47 AM
11-12-2014 09:18 AM
With NI-Scope installed the device should show up in MAX, Measurement and Automation Explorer. Under Devices and Interfaces the device should be listed, and a test panel can be opened to perform basic scope functionality.
You can also write your own application that uses the scope using drivers that get installed with NI-Scope. If you have LabVIEW installed first then examples will show up in the Help >> Example Finder in LabVIEW that shows some examples on writing code to interface with a scope.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
