03-03-2010 02:40 AM
Hi all,
I'm acquiring a signal from an accelerometer using PCI 6251 card. Graph below shows the signal acquired. I need a smoother curve for this data..
I was confused trying to use the curve fitting from mathematics function palette ( it asks for X,Y etc) also in express curve fitting it says my signal matrix is singular.
thanks a lot
03-03-2010 03:35 AM
03-03-2010 05:27 AM
What is signal and what is noise?
I would try a FIR lowpass filter with a Kaiser window and shift back the signal half order points to correct the phase (if needed)
Something like curve fitting is the Savatzgi-Golay filter, also worth a try 😉
03-03-2010 08:44 PM
The signal is from an accelerometer fitted inside of a helmet that is dropped from a certain height.
When I use just the moving average filter, i do get a smooth curve, but the peak value has also changed (along with some shift..that is OK)...
For my application, peak value is important so it should not change...
03-03-2010 09:13 PM
Henrik,
Fir filter does not alter the magnitude that much.. I used the express VI filter FIR with 29 taps...where can i find the kaiser window? i din't find in the mathematics menu
03-05-2010 01:22 AM - edited 03-05-2010 01:26 AM
FIR Windowed Filter VI in signal processing/Filter or hit Ctrl-Space and use quick drop to search 🙂 has an input to define the type of window used.
As already mentioned (but misspelled) the Savitzky-Golay Filter is a good tool to preserve maxima.
What sample rate are you using?
What type of sensor are you using and what uncertainty are you expecting? I ask because maybe you need to take look at the influence from the high pass of your sensor amplifier chain (assuming charge based sensors)
03-09-2010 01:32 AM
Henrik,
Initially I was sampling at 5k. Later we changed the sampling to 100kHz (since we are getting a very short impulse ) Now the signal is lot better.
we are using a piezoelectric accelerometer sensor with 1msec/g.
thanks for your time
