Slow array VI
I have created a small VI that has to search 210000 data points.
Using a for loop, starting at the first point and selecting a sub array of the next 700 data points and then I return the minimum value from this subarray and I then write this value to a blank array (minimum number array) via a shift register.  Next I move forward 1 point and create a new subarray from this data point forward 700 points and then return the minimum point from this subarray and write this value to the minimum number array via the shift register.
Once I have done this 210 000 times I then get the maximum number from my minimum number array.
This array takes 10 minutes to run, can I speed this up?
(2,207 Views)
Hi R_ATS,
it takes ~300ms for me (including data generation!):
(2,205 Views)
I was getting around 360-380ms from Gerd's code.  I and getting around 350-375 with this code.
GCentral
(2,182 Views)
         You can save array comparisons if check the values with index i-1 and i+700.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
(2,173 Views)
Instead of taking slices (sub arrays) of the original array to work on I thought you could take one initial slice and use smart indexing to replace the element as it loops.
I seem to be getting a consistant 168 on this version...
(2,155 Views)
