09-08-2014 08:52 AM
I bought a Single Board RIO 9636 which is to be used in a battery-powered system. Hence, power consumption is critical.
I hoped I could use the sleep mode that is mentionned here (p29) and here but the "sleep I/O item" does not appear in the Labview project.
Do I have to do something special to make this I/O appear in the FPGA I/O?
Does my SBRIO support sleep mode?
Any idea of the kind of power consumption I can achieve with sleep mode on? Is there a big difference compared to regular mode?
peper
09-08-2014 08:59 AM - edited 09-08-2014 09:02 AM
Peper,
You are actually referencing the previous generation of sbRIO's manual in this post. It is a bit confusing at that manual was labeled 963x. If you go to the sbRIO-9636's product page, you can select "Resources" and get to the prodcut manuals from there. Here is the sbRIO-9636's manual.
The Sleep I/O item allows C Series module to enter a sleep mode, not the sbRIO controller itself; therefore, the sbRIO-9636 does not have a Sleep I/O item under the FPGA target in the LabVIEW Project.
If you want to go into a lower power state, you can stop the FPGA bitfile from running which should lower the power consumption (you can do this with the FPGA Abort invoke node with the FPGA Interface that runs on RT).
09-08-2014 09:19 AM
Too bad to hear that the SBRIO we bought does not have a sleep mode. The information provided by NI is indeed very confusing.
We did implement the "abort FPGA" method but, unfortunately, did not see a difference in power consumption.
Anyway, thanks for your answer!
peper
12-05-2014 02:58 AM
12-05-2014 01:08 PM
Hi henningL,
You are correct in that the Sleep I/O Node is not a feature for the NI 9693; therefore, it cannot be change within the LabVIEW Project. The SLEEP line is actually active low so it is not driven low on for this product to prevent the modules from always being in sleep mode. The C Series modules connected to the NI 9693 are always in their active modes. I hope this clears things up.
12-19-2014 02:37 AM
