04-06-2017 06:21 AM
The thing that I see is that the waveform you send to the Analog Write is coming from a feedback node. On the first run of your VI, that feedback node will give the default value since nothing is wired into the initializer terminal. The default is going to be an empty waveform.
Beyond that, that node will only run once because it is not inside the while loop. So there is really no point to having a feedback node at all.
04-08-2017 04:25 PM
Hello Ravens Fan,
If you don't mind, can you elaborate on what you mentioned? Do you know of any tutorials I can read on that can assist in helping complete what I want?
Thanks in advance
04-08-2017 04:52 PM
What I essentially want to do is something like this. I understand how most of the configuration is working, except I do not know where exactly I would put the write VI as well as the Harmonic Analyzer VI that I wish to use.
04-09-2017 06:10 PM
Hello RavensFan,
So I was able to configure my VI in this manner. When highlighting the execution, it works for the first few iterations and then I get this error. I am unsure on how to handle the error. Any suggestions? I have attached the a snippet and a VI for your reference. Thank you in advance. I appreciate the help.
