12-09-2005 11:16 AM
12-09-2005 03:40 PM
12-10-2005 07:34 AM
12-12-2005 05:54 PM
12-12-2005 09:11 PM
Hi Jaideep,
Thanks for your answer. Unfortunately, I tried to change the numeric control to floating point format and to increase its digits of precision with no results. The value 0.00001, which should be displayed properly in a floating point control with 6 digits of precision, still gets converted to 1.000000. I really think that the value is converted to an exp/fractionnal string on Matlab's side but is not converted properly back to a floating point value on Labview's side. The exponential part seems to get dropped in the process.
You're right that I can acquire the value from Matlab as a string and convert it to a number later, but I have quite a few variables to transfer from Matlab (over 150) and adding these conversions would be quite a big headache.
This behavior seems odd to me, and I'd like to understand why it happens so...
Thanks again,
Alex
12-13-2005 02:14 PM
12-13-2005 02:57 PM
Hi Gretchen,
Thanks a lot for your help. We use SIT 2.0 (i guess, it was bundled with LV 7.1, any way verify?). I applied the 2.0.3 patch...
Let me know if you need any other information.
Thanks again,
Alex
12-16-2005 02:08 PM
01-09-2006 11:50 AM
Hi guys,
Did you find a workaround regarding the bug that occurs when we transfer small values from Matlab to Labview? Your help would be greatly appreciated on that issue.
Alex
