Greetings, 2Penny:
You are right about this forum being the best way to get information in a hurry. There are countless thousands of man-hours of experience right here!
One of the best tools for analog circuit simulation is the FORMULA node. Think of any analog component as a mathematical engine that performs some function upon an input signal. As a ridiculously simple example, you can model an amplifier with a simple multiplication function..i.e., the output signal is the input signal times the gain. As you get more sophisticated, such as adding feedback, of course, the equations will become more complex. However, ANY analog circuit can be represented by one or more formula nodes. I recommend that you look at some semiconductor data books to get
a feel for characteristic curves which can all be modeled with fomula nodes. (True circuit modeling programs like SPICE perform a similar function) Labview traditionally hasn't been the ideal platform for modeling raw components like transistors, being far more at home in simulating SYSTEMS, but it's becoming much better for "low-level" modeling, especially when combined with Matlab and other external engines.
There are a lot of analog modeling examples on this Labview site, as well...although you may have to spend some considerable browsing time.
Hope this has been of some help. Good Luck!
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
