09-05-2014 09:10 AM
Hi All,
I want to simulate click for buttons (with latch mechanical action) that are in sub panel VI so as to trigger its action.But I couldn't achieve it in the way I can simulate a click for any other buttons in the Main VI. I have attached a sample program to explain my problem,please let me know what is my mistake.
Thanks in advance,
S.G.Sree Ranjani.
Solved! Go to Solution.
09-05-2014 10:05 AM
09-07-2014 11:24 PM
Hi Guru,
Thank you but I need to simulate this Click action without making any changes in the VI which I call in sub panel.
Sree
09-08-2014 06:11 AM
It's an interesting problem. I downloaded and tried to make it work but was unsuccessful. I'm only posting to let you know you're not alone in trying this. 🙂
09-08-2014 08:49 AM
just a minor mistake.
Jim you missed it.
Here you go.
09-10-2014 01:11 AM
Thanks Neos,
I hope this solution will work can you please explain why this change should be made.
Sree
09-10-2014 02:00 AM
SreeRanjani wrote:I hope this solution will work can you please explain why this change should be made.
Your post does NOT contain the solution and should not be marked as such.
Please mark the most helpful post as solution, not your own!
09-10-2014 02:48 AM
Sorry,
I marked my post instead of the previous post
09-15-2014 12:38 AM
Hi Neos,
Your Solution is working , can you please explain me why the change is made and how it is working now.
Sree
09-15-2014 02:28 AM
@SreeRanjani wrote:
Sorry,
You can easily correct that at any time, so please do.
