Simple serial loopback test
Hi. I have been reading more info about the use of serial port in my PC.
Using the Hpyerterminal program, I am able to get response using the loopback test as instructed from NI website's tutorial.Smiley Very Happy
Now I proceed to use the LabVIEW <-> Serial.vi from the provided example in my Labview Development Software.
Again I use the loop back to read the sent string. Somehow, I got errors when performing it for the first time.Smiley Sad
I could not find help from the Labview software or forum here. Smiley Mad
There are two things in the LabVIEW <-> Serial.vi which I cannot understand.
They are : resource name (Control) and VISA Configure Serial Port.vi. That error comes from VISA Configure Serial Port.vi.
The error is "Property Node in VISA Configure Serial Port (Instr).vi->LabVIEW <-> Serial.vi"
So how do I solve the problem?
Message 1 of 9
(3,377 Views)
1. The resource name control is where you choose your serial port: com1 , com2 ...
2. Visa conf. serial port is where you set the  parametters  of  the port : baud rate, parity, flow control...
For your error, it might comes from the fact that the port is currently busy.
Message 2 of 9
(3,375 Views)
Hi thanks. But the hyperterminal program is closed,  meaning that the serial port is now closed.
There are no other programs using the serial ports
How do I find out  if one  or all  the serial port is busy?
CheersSmiley Very Happy
Message 3 of 9
(3,359 Views)
Is "resource name" control pointing to an available port on your machine? Try opening the port on wich "visa conf. ser port" hung in hyperterminal to see if it is busy or not. Also, try telling the program to continue on the error pop-up dialog, to see if execution will continue normally.
Message 4 of 9
(3,346 Views)
What is the actual error number that is being generated? That's an important piece of information you need to provide. Also, attach a picture or the VI with the actual settings you're using. If you post a VI, if you're using front panel controls to set the parameters, be sure to first select Operate>Make Current Values Default and then save it. There's an awful lot of possible causes for an error and the more information you provide, the quicker a solution can be found.
Message 5 of 9
(3,342 Views)
Hi. Dennis and Electro gab,
Here is a pic of error msg, and there is a vi for you to try it out.
The resouce I am pointing to is Com 1. I cannot continue the program after the error. I set the "select type" of VISA configure Serial port to automatic. But I am not sure about the "VISA Resource Name" Control's Select VISA Class > IO Session >Instr. Is Instr correct. Must I have NI VISA Driver?
Cheers Smiley Very Happy
Clement
Message 6 of 9
(3,317 Views)
Yes, you do need the NI-VISA driver.  The page is linked below with a KnowledgeBase about that specific error you are getting.  I hope this helps!  Have a great day!
Chris R.
Applications Engineer
http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US
http://digital.ni.com/public.nsf/websearch/6055CCB1C032D1DD86256C32004EC84D?OpenDocument
Chris R.
Message 7 of 9
(3,289 Views)
As mentioned, the error code indicates you don't have VISA installed. The description for the code is installed along with VISA. So, if you have VISA installed, you won't get the error, but, if you don't have VISA installed the description won't exist and you don't know what's wrong. I hope that in the future, NI can include this description in the LabVIEW installation.
Message 8 of 9
(3,276 Views)
Hi Chris and Dennis, Thanks. It works and I just realise.
Message 9 of 9
(3,247 Views)
