Simple problem with a square wave and a boolean LED
Look this is the case,
Im making a test for PCB, it has a emergency switch and a buzzer. the buzzer is connected to the emergency switch with a microcontroller
Case 1: Emergency switch isnt pushed in , buzzer makes no sound (hardware) and therefore the LED in my program stays off.
Case 2: Emergency switch is pushed in, buzzer automaticly makes sound (in a square wave form: 1 second high, 1 second low (3x)). But if i put this in the program the LED will blink.. because the signal is high/low. What i want is that the LED will stay on.
So my question is: is it possible to put a square wave output on a led and keep that led on. (it should not blink).
and if it is not allot of work can you please show me how to do it with a simulation.
(english is not my native langueage thats why i cant explain it very good)
With kind regards,
Asrih
Message 1 of 13
(4,176 Views)
You can accomplish that several ways. For example you can check if chcange occured after 1 second - if so - keep the true state.
You can check the number of transisions from false to true (since you know the number of changes of the buzzer)
However it will require the knowledge of incoming singal - how long will it last, or what are time intervals or how many times it will change...
Message 2 of 13
(4,151 Views)
Is it possible to get access to the earlier value from the switch itself? That would be steady, but technically would only show the switch closure and not the buzzer being energized.
Adam's suggestion is a good one, but would result in a delay in it being turned off due to the timeout.
Personally, I would say that the best solution is to let the LED blink as it is showing the buzzer's current state exactly.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 13
(4,146 Views)
could you please show it me in a program, im new to labview
Message 4 of 13
(4,138 Views)
Here is an example of using the Time Elapsed function.  As MikePorter mentioned, it does have a 1 second delay to turning off.
The best solution is to fix this in hardware and get the raw switch signal instead of the pulse signal.
GCentral
Message 5 of 13
(4,128 Views)
im sorry but i dont understand what you did there, where is the LED and the square wave
Message 6 of 13
(4,112 Views)
Hi Asrih,
You can find my suggested solution attached. On the left side of the vi, we are generating a square wave of total simulation time. On the right side (marked with a decoration frame with an arrow pointing to it) we are simulating data acquisition generation at Rate of generation constant. On the right side you can see the indicators for the LEDs. As you can see, the Held LED is now always on for the Total simulation time.
You can download the vi, test it out, change the values of the constants to see how it affects the behaviour.
Hope this helps!
Message 7 of 13
(4,055 Views)
Hi Asrih,
it is considered rude behaviour to create new threads for old/same topics
I also consider it as "rude" to beg for help using PMs…
Message 8 of 13
(4,040 Views)
hi GerdW
My problem wasn't solved.
and nobody was helping no more... so i tought i'll send you a PM, but you didn't help me after that eighter... sooo... i tought i'll bring the topic back up again.
so you read my pm and didn't help me... thnx
Message 9 of 13
(3,996 Views)
NI-Mikko,
First of all thanks for your reply,
second, i'm using labview 14 and you 15, i can open it.. could you please make a printscreen out of your programm?
with kind regards
N.asrih
Message 10 of 13
(3,991 Views)
