04-20-2006 09:25 AM
04-20-2006 09:37 AM
04-20-2006 10:03 AM
04-20-2006 10:31 AM - edited 04-20-2006 10:31 AM
When I run that VI is asks to setup the data link properties.
Select ODBC in the Provider tab as shown. Then goto the Connection tab and select Labview then test your connection. Click on OK when happy. The vi should work.
Are you doing that?
David
Message Edited by David Crawford on 04-20-2006 04:32 PM
04-20-2006 12:24 PM
04-20-2006 12:38 PM
Hi Pallen
Try creating a .udl file that points to your .mdb. It tells you how to do that in the manual. There is an example .udl shipped with the DCT and can be found under examples\database in your labview installation.
Hope this helps
David
04-20-2006 12:43 PM
Oh just thought of something. If you are doing this with one of your own mdb it might be better to select the Microsoft Jet 4.0 option on the Provider tab. The Connection tab will then allow you to browse to the mdb that you want to try.
I am doing this from memory and I don't have labview at home so I apologise if I don't have all my facts straight as I can't try it out.
David
04-20-2006 01:21 PM
04-20-2006 02:03 PM
04-20-2006 02:21 PM
