Simple Bluetooth Server/Client on the same machine
Hello everyone,
i have a simple question about the Simple Bluetooth Server/Client example. Maybe the answer is obvious and i'm just an idiot but nothing is written about it in all the topics i read:
Simple Bluetooth Server.vi and Simple Bluetooth Client.vi can be run on the same machine?
(3,328 Views)
Accepted by topic author frax84
Hi Frax,
the device you want to connect with and the pc must be different, because the communication works with address and I don't think it'll like using the same address for server and for client...
Do you have any problem to use this example?
Hope it helps,
let me know!
FBM
(3,301 Views)
Hi FatBoy,
Yeah, i tried to use the VIs on the same PC and i was going crazy to make them work. I got confused from previous experience with TCP/IP applications and similar, so i thought i could use the VIs on the same machine.
Thank you
(3,296 Views)
Glad to be helpful,
have a nice day!:)
FBM
(3,285 Views)
