08-14-2009 05:32 AM
08-14-2009 09:45 AM
08-14-2009 09:56 AM
repeat...please continue on
http://forums.ni.com/ni/board/message?board.id=300&message.id=5169&jump=true#M5169
08-14-2009 10:04 AM
ALL TYPES of thermocouple will be hard to find unless you buy a converter from Omega or Phoenix Contact
But you may start with AD594 or MAX 6675
Is this also for your PIC 18F..... project?
If yes I think you better off with raw IC isn't it?
08-14-2009 11:44 AM
Unless you absolutly HAVE to use your ADC, I recommend the PICO Technologies TC-08 USB. You can't beat the price for 8 thermocouple inputs. I've found it to be very accurate (when simulating signals from my Fluke Thermocouple calibrator). It also supports a fairly large range of thermocouple types.
I've written some LabVIEW drivers for the device. I've been meaning to clean them up and submit them to NI so that they can be available for all. Hit me up if you want them. The only draw back of the device is you can only get about 2 samples a second.
If your application requires faster sample rates or more configuration options, I would look at the AD594 and AD595 product line from Analog Devices. You will have to make your own circuit boards for these instrument amplifiers but following their application notes makes the process pretty easy. I use these for my applications that require fast response in conjunction with Omega bare wire thermocouples (that come as small as 0.0005" wire diameters and are very fast).
10-21-2009 05:29 AM
Can you send me your LABVIEW driver for the TC-08 USB and easy to understand examples?
Thanks!
10-21-2009 06:47 AM
11-12-2012 04:14 AM
Hello to everybody!
I'm trying to acquire a themocouple signal by means of Pico instrument. In particular, I'm using the USB TC-08 device. When I bought the instrument there was a labview VI together with it. Unfortunately, I have to implement the device in a old VI with different acquisition instruments (like ABB analyzer, and pressure signal from a National Instruments DAQ signal). Finally I have to coordinate the acquisition signal in order to acquire a coherent signal in time from different instruments.
I have little experience..so I'm waiting to obtain an help from someone.
Thank you in advance for your help
11-13-2012 08:14 AM
PicaPica,
Are you saying that your USB TC-08 device came with instrument drivers for LabVIEW? If that's the case, you could try incorporating the functions from these instrument drivers into your overall program.
Leah
