04-01-2016 07:17 AM
Hello
Working with Signal Processing / Signal generation palette I have met some difficulties.
Here are some of them:
Thanks in advance
Solved! Go to Solution.
04-01-2016 07:44 AM
04-01-2016 07:50 AM
@Pavel_47 wrote:Hello
- some blocks works properly, whereas others not at all, e.g. on the snippet that follows there are 2 signal sources: Gaussian Modulated SIN pattern that works ... and another, the simplest Sine wave, that doesn't work
- default realization of the Tones and Noise block contains only 2 tones. Is it possible to add additional tones ? How ?
Thanks in advance
What do you mean by 'doesn't work'? Are you getting an error? Have you probed the array of data coming out? I'm pretty sure that these functions all work, so what are you getting versus what you are expecting?
The Tones and Noise VI takes in an array of tones (array of clusters) - increase the size of the array to add additional tones - that is pretty basic stuff.
(I can't open/run your snippet as I don't have LV2015)
04-01-2016 08:04 AM
Tones and Noise - Ok !
I was confused by greyed aspect of new tones while dragging the right side of the array (so I thought that exists some sort of "activation")
But once I change the frequency, it becomes "normal".
Concerning "doesn't" work: here is 2 outputs: Gaussian Modulated SIN (top) and SINE wave (bottom)
What version of LV you have ?
04-01-2016 08:29 AM
04-01-2016 08:59 AM
Indeed, it's the case.
Before I used another block, where the unit was [Hz]
